Front pinion seal removal
  • Cevan
    • Jul 2011
    • 57
    My front diff does not have a removable pinion seal flange. Can the seal be removed without removing the ring and pinion assembly? I've tried using heat and a slide hammer to no avail. The seal seems to be one of those metal and leather ones. I can't really pry it as the pinion is in the way.
    If I have to remove the R&P, is it just a matter of removing the 4 bearing cap bolts? My green bible is silent on this. Any idea on the torque value for these cap bolts?
    1976 Honda CB750F1
    1974 Honda CB360G
    1967 Series IIA
  • siii8873
    • 1013
    You should be able to pry it out without removing the assembly. There is a little tool made for removing these type of seals. It essentially prys it out. The certainly can be a PITA for sure to get out.
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
    • Cevan
      • Jul 2011
      • 57
      Ok, I'll bite. What is this little tool you are talking about? I couldn't find anything on the RN site. The pinion just seems in the way if you try and pry out the seal. I don't want to damage the spines on the pinion.
      1976 Honda CB750F1
      1974 Honda CB360G
      1967 Series IIA
        Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!
        Something along these lines, although this particular one may be too big and they usually work better with the shaft removed. I can't remember but I may have been able to get a slide hammer attachement under it too.
        • Les Parker
          • May 2006
          • 2020
          Jason,
          I'd favour the 2nd (Right hand) pic. over the 1st (Left hand) option.
          Les Parker
          • siii8873
            • 1013
            yes that's the tool on the left. I have removed a few pinion seals in place with this type of tool
            • Cevan
              • Jul 2011
              • 57
              Just thought I'd follow up. The seal removal tool worked like a charm. Thanks.
              1976 Honda CB750F1
              1974 Honda CB360G
              1967 Series IIA
