color me frustrated..
Had small leak at joint of left front brake hose and wheel cylinder. Like that for months but eventually pedal started getting soft and finally was pumping up significantly. So I replaced the wheel cylinder AND the hose on the idea that maybe the PO cross threaded the hose into the cylinder.
So now I can't bleed the brakes.
Have tried twice - bled all 4 wheels, started with the back - no air visible there, pulled the wheels and did the fronts. Got lots of air bubbles both times. Once bubbles stop, get a firm pedal that pumps just a wee bit. Put the wheels back on (take maybe 15 minutes) and pedal goes back to the floor again and pumps up.
I've checked the adjusters and they're all ok - tight and then back off 2 clicks.
Bad (new) wheel cylinder? Bad connection at brake line to hose? Bad connection at hose to cylinder? Something else? I've checked all my connections (despite including them in my questions above) and all look ok. Where can the air be mysteriously entering?
I'm considering putting my original wheel cylinder back in...
And on another note - I got a set of AllMakes brake shoes for front brakes from another vendor (RN is completely OUT of shoes until sometime mid January 2013) and they are too WIDE. When I tighten up the screw that holds the drum on they lock up the drum. Back off the screw and the drum turns. I ran a die grinder (Dremel) down the side of the shoes along the plate under the brake material and that didn't help. The size is close - these are itsy-bitsy just a bit MORE than 2" and my old shoes are itsy-bitsy just a smidgeon LESS than 2" wide. Obviously enough to make a difference...
Is it ok to grind down the side about a 1/32 or 1/16" (wearing a face mask of course)? Or do I just give them up as a bad business and cheap POS?
I've got a friend who is extremely Rover savvy coming by maybe tomorrow to lend a hand - maybe third time will be the charm...
