Does anyone know where I could source the small washer sized "rubber" gasket that is on the bottom of the Brake and Clutch metal reservoir found on '67 Series IIa? It looks like it tore when I unscrewed it from the bottom of the can. If no simple source, then what the gasket material is that holds up to Brake and Clutch fluid that I could fashion my own?
I did find this posting on gasket material website for SBR:
SBR (Styrene-Butadiene Rubber)
SBR is a synthetic polymer with properties similar to Natural Rubber. It has good water and brake fluid resistance along with good abrasion resistance. It has better heat temperatures that Natural Rubber. SBR should not be used for applications in contact with strong acids, ozone, oils, fats greases and most hydrocarbons.
Also on TPE (Thermoplastic Elastomer)
TPE also known as TRP is a thermoplastic material the has some rubber like properties but process like a plastic material. They can be used in applications where temperatures range from minus 40 degrees centigrade to 125 degrees centigrade. TPE has excellent resistant to polar fluids and fair to good resistance to oils and hydrocarbon fluids while offering good electrical properties.
Sounds like Hylomar Universal Blue is resistant to the DOT-4 brake fluid we use.
