I've done this alot over the years , the replacement studs are shorter. you can buy these thru our host. Yes you will need to remove the hub to do it properly, the replacment stud willl have threads , splines and the shoulder. I over drill the hub to match the opposite end ( the flatten end, looks like a nail head) by about 1/4 inch at the most ,press it in to match the correct length, and tack it with a welder.
