Anyone familiar with a bellhouse leak on a series II Rover? What the problem may be and what part to check/replace? I don't have the technical skills to rip out a transmission and pull it apart, so looking for some indicators that may require a little less time and money.
Bellhouse Leak
If it's engine oil it has to be the rear crankshaft seal, if it's gear oil it has to be the front gearbox seal, if it's clutch fluid then it's the slave cylinder. Check the level of the clutch master cylinder, if it's down that will be the problem, they are cheap and easy to replace don't bother with a kit if it's not the clutch slave then it will require a lot of work.1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.Comment
The SII\IIa transmission doesn't really have a front seal so they seem to alway weep a little. As others have said though it's not uncommon to have a leaking rear main seal too. Sometimes they can go for a long time and not get worse, sometimes they just blow!
Check your motor oil level and gear box levels often and see which one(s) you have to top up more frequently. This may indicate what is leaking into your clutch housing.Jason
I agree with everyone here and their suggestions. I would, as a hope/pray suggestion, check the oil pressure gauge line if you have a mechanical oil pressure gauge in the dash.
I had my line desintigrate behind the engine, and it caused motor oil to drip onto the bell housing, and down the side. I did have a rear main seal leak also, but this oil pressure line was causing a significant amount of oil loss.Bad gas mileage gets you to some of the greatest places on earth.Comment
We have had two oil pressure lines fail on trucks. Both were braided stainless lines and both times ended up having issues with the engine not being grounded well enough. I now use nylon tubing so it can not act as a ground for the engine. It is truly amazing how quickly the motor can pump its self dry with a busted pressure line!Comment
Crap.
Looks like I am going to have to replace the dual master cylinder to fix the brake problem as well. Any advice on buying Genuine Rover Parts versus the Proline series? Also, I'm a newbie, so just curious how much time/level of skill is required to replace the master cylinder? The Haynes manual makes it look pretty easy, but I've never done it.
I'll take a look at the leak later.
Thanks for the advice.Comment
Is there a correlation between the master cylinder and slave cylinder? If i change the master do I need also to change the slave cylinder?Comment
You don't need to change the slave cylinder when you change the master cylinder, but as the parts are reasonably inexpensive, most change them both out based on their age. That includes the pipe work. The rubber flex hose is prone to failure over time, and the metal pipe corrodes and may as well be replaced if it looks questionable since you have it all apart.Bad gas mileage gets you to some of the greatest places on earth.Comment
The brake master cylinder is easy to get at, but the clutch master is a bit tight. There is no brake slave cylinder really, every wheel has its own slave I guess you could say.
The clutch slave cyl is down under the trans tunnel on the passenger side, easy to get at if your floor panel hardware comes out easy, not so easy if all your hardware is corroded. I rebuilt my clutch master which is an easy job if you have a bench where you can be clean and take your time. Getting to it is a different story though, the wing top is in the way. If you do decide to take your wing off to get at what you need, then you might as well rebuild or replace both cylinders while you're there, especially if your brakes are dicey. In my opinion, if you wanted to do the best job possible you could send the cylinders off to be bored out and brass lined.
If you get the the wing off its good time to look at what else is down there (steering box etc..) As you can see though its all too easy to get into everything!! Resist, or you wont be driving your truck for a few months.
have fun!
~Ste---- 1969 Bugeye ----
---- 1962 Dormobile ----Comment
