I'm working on testing my gauges befor assembly. One question I have is on the voltage regulator. There are two connections marked "I" and "B", which connects to the source and which to the gauges? Also on a test bench does the case need a ground reference (ground case).
I also tested my fuel level sending unit and it measures from around 30 to 200 Ohms sound correct?
