having trouble priming the fuel pump. removed the pump, cleaned it and it appears to be operating correctly. fuel is reaching the inlet port on the pump, but not reaching the sediment bowl. Any tricks to priming the pump? Or suggestions.
64 SIIA 109
Dumb question, but are you working the priming lever hard enough? It can have enough play to fake you out for a while.'67 109 NADA #413 - rebuilding w/ TDI & galvy chassis. -
Only other thing I would suggest is to take it apart and inspect he check valves and diaphram. Perhaps the stem that acuates the diaphram is worn not allowing for enough travel. There really isn't much to them.Jason
Don't forget the old "engine stopped with the fuel pump cam lobe in the actuated position under the pump's follower arm" routine if you're doing it by hand instead of just cranking the engine (I doubt you are, but I thought I'd add that just in case).--Mark
