I am fitting new swivel balls and Railko bushings. The green bible states that the Railko bush should be "a light push fit" on the swivel pin. The new bushes were a moderate push fit on pin before they were pressed into the new swivel balls. After pressing I cannot get the pin to start into the bush on one side and the other side is a hard push fit into the bush.
Has anybody encountered this issue before with new Railko bushings? The green bible has nothing to say about tight bushes only words to replace the bush where the fit is too loose between the pin and the bush.
