Runs fine, never happens on flats or uphill. But if I am going downhill and stop at a downhill angle the idle slows until it stops. Just seems to starve out. If i choke it a bit or rev it its fine.
I am assuming this would be a float level issue (zenith) and I need the float to float a bit higher before it shuts off flow so the bowl is a bit more full. Before I crack it open however I thought I would tap the wisdom here to see if anyone had experienced a similar issue. I hate carb issues.
