I would say that the variable ignition timing at idle will be a prime concern. If you aren't able to nail down the timing using a few conventional methods, something's wrong.
I'd check the security/gap of the points, the integrity of the centrifugal advance springs and weights, the function and integrity of the vacuum advance system and mechanism AND, since almost ALL of the brand new capacitors are crap, I'd also replace the capacitor just because. Probably try to source a GOOD capacitor from from Advanced Distributors. Though I have no distributor on my engine, I've heard nothing but good things about them, their distributor rebuilds and their capacitors.
Might also check for excessive play in the distributor and shaft.
Compression check is also in order, though I don't think It'll reveal a cause for your problem, personally. Maybe throw a vacuum gauge on there as well. Check for vacuum leaks while you're at it. Check for malfunctioning choke too.
Anyhow...that's the tack I'd take initially. It just boils down to the old fire triangle; fuel, oxygen and an ignition source.
[EDIT:] Wow--missed a whole other page of replies. Apologies for the duplicate recommendations en masse. I think the Advanced Distributors recommendation is original though...
