I can't seem to get the two manifolds to come apart. I took all the nuts and bolts off and they are out of the truck but, it appears that the two are cooked together. Anybody had any luck unsticking them? Before I start whacking away with a hammer I thought I'd ask around.
Exhaust and intake manifolds stuck together
I would set up a electrolysis tank and let it soak. Give it a day or so and the rust will convert to iron oxide and the parts will come apart easily. Here is a site to get you started.
Rick73 xMOD S3 109
52 M37Comment
Rick
I would use heat.Comment
Use a plastic dead blow or brass hammer on the intake. Should pop loose.Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZFComment
