I put a speedi sleeve on my 2.25 front crank pulley and it leaks worse. Sleeve is in the correct place and the correct diameter. I didn't use anything to seal it but thought it was tight enough to seal by itself. Any tips would be appreciated.
Speedi sleeve issues
sealant
you do not need a new pulley you just need to put sealant on the speedi sleeve. metal to metal is never going to me an oil tight seal1968 battlefield ambulance/camper
1963 Unimog Radio box
1995 LWB RRComment
I've never had luck on the crank pulley, even with sealants. New seal and pulley was the best solution for me.Jason
Well if you're industrious enough like me, you simply take your used 90 wt or motor oil(or a blend to be authentic), put it in a garden sprayer and use it to mimick the leaks as if you were doing 50 mph on the interstate. Kill two birds with one stone because then it drips all over you driveway like it would in nature. (Except you probably can't tell by now with your driveway).Jason
Yeah, you should use sealant under the sleeve and wiped off the excess. I like the black oil resistant hi-temp stuff myself.Comment
In progress
