Steering Wheel Refurb - Any One Do It?
  • amcordo
    • Jun 2009
    • 740
    There are posts on here about doing it. I'm not looking to do it myself, but rather I want to know if anyone on here is willing to do it for me? Let me know your price!
    Mine is just suffering from the usual sticky situation that eventually develops on all of the S3 wheels.
  • artpeck
    • Dec 2009
    • 368
    After doing a lot of reading I took mine off. Cleaned it with a mild solvent and buffed it with fine steel wool. I then painted it with a paint specifically for plastic and it has been great since. Wasn't hard at all.
    • jac04
      • 1884
      Just bring it to your local body shop. Have it prepped & painted with a high quality urethane automotive paint.
      • airbornrover
        • May 2012
        • 17
        If I remember correctly there is a shop/company in the UK now that is taking old steering wheels and making them new. Like Artpeck said just take it off sand it down, making sure to grind or sand into the cracks/splits. Then fill in with epoxy, sand everything down, wipe down. Last is hit it with some epoxy paint a few times and it will look good. I used rustoleum epoxy spray can stuff that is used on appliances.
        • rwollschlager
          • Sep 2007
          • 583
          you can finish it off with one of Ike's sweet covers when you're done
          72 SIII 88
          67 SIIA 109
          82 SIII Stage 1 V8
          • busboy
            • Nov 2012
            • 202
            I recently chipped my steering wheel and have been wondering what to do as it too could do with a make over. After reading the replies here it seems that the paint is not that important. So far we have a paint for plastic, a urethane automotive paint and an epoxy paint. I do have some black urethane auto paint I could use but that needs to be clear coated to finish, I do have clear coat but not sure about clear coating the steering wheel or perhaps that's exactly what it needs to protect the paint from wear. I could give the clear coat an "orange peel" effect or perhaps not as that would tend to show wear more.
            1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.
            • Eric W S
              • 609
              Repainting the wheel will not stabilize it or prevent any future rot. The bakelite is degrading. Painting it does not stop that. You need to send it to someone who will recast the wheel in a poly plastic. That is the only long term solution.
              • amcordo
                • Jun 2009
                • 740
                Eric - that's what I was thinking. I think I"m going to have it chemically dipped to remove the bakelite stuff, then I'll find somewhere to dip it.
                • westcoastkevin
                  • Jan 2011
                  • 162
                  Or you can do it at home.
                  I sent you a PM Anthony too.
                  • amcordo
                    • Jun 2009
                    • 740
                    Your box is full.
                    • westcoastkevin
                      • Jan 2011
                      • 162
                      Not any more. I did not realize.
                      • Revtor
                        • Apr 2012
                        • 265
                        hmmm bakelite is pretty stable stuff. You really think you have to remove all of the plastic from the wheel and remold a whole new rim? Seems drastic. Like just get another wheel drastic.
                        I would at least try some wet sanding, epoxy, more sanding, and then a good paint job first. then if you decide the wheel is toast, you can spend and have the whole thing remolded, or just find another in good shape.
                        ---- 1969 Bugeye ----
                        ---- 1962 Dormobile ----
                        • Donnie
                          • 287
                          Check Hemming's, there are guys in there that specialize in steering wheel restoration......Donnie
                          • hankster110
                            • Jul 2012
                            • 30
                            My Banjo wheel was sticky and degrading, I put one of Ike's covers on it and Bob's Yer Uncle. Worth every penny.........
                            Hankster110
                            • Eric W S
                              • 609
                              It's not Bakelite. It's similar. If it was stable, it would not rot and come off in your hand.
                              Drastic? Common place in a proper restoration. Other marques do it all the time - from Land Cruisers to Mustangs. Problem with decent wheels to replace one is they are hard to find and cover a good deal of the cost to recast a wheel. Mosat are running about 100 for a decent wheel.
