I am replacing rear brakes on '71 Series IIa. Hub seals were shot and gear oil had leaked all over the inside of the brake drums and looks like it saturated the brake shoes. I read in another forum from Australia that the cast iron of brake drums is porous and would soak up the oil and therefore need to be replaced. Is this the case? Given they surface gets very shiny it seems like it would be hard to penetrate the metal. One post suggested soaking the shoes in gasoline and "burning" off the oil!! Thanks for any help in advance.
Brake Drums "Saturated" with oil?
I remember my Grandfather burning oil soaked brake lining/shoes a lot of years ago. He said it removed the oil and helped recondition the lining somewhat. I dont know if it would work with todays materials or not. As to the metal soaking up oil, I would use lots of brake cleaner on the drum and press on.
Jim1963 Series 11A 109, Left hand drive, Koneg PTO winch, ACR 2.8L 5 bearing power plus Engine with weber carb. Truetrac gear driven limited-slip traction rear differential. -
Fix leak, buy new shoes and springs, clean drum with brake cleaner as suggested. Put it together and have fun driving it.Jason
