What diffs will fit in a stock series axle housing?
  • ArlowCT
    • Jul 2008
    • 238
    I'm looking into changing / upgrading my diff in my ser III 88". Would like to swap to 24spline half shafts, and a stronger carrier. Would also like to gear down to lower gears (numerically higher). Any suggestions would be great.
    Thanks!
  • SalemRover
    • Aug 2007
    • 310
    Wouldn't it be easier to try and source a T-Case with the lowest possible low range. I cannot say as I have ever heard of a any higher gearing than 4.77 in a series. Maybe a IIA / III one ton transfer case would be a significant boost in low range performance.
    • blue bomber
      • Dec 2011
      • 48
      ARB or trutrac's are your best options. I have ARB's with maxi-drive axles and 3.54 R&P's. With a stock engine and trans, I would consider the overdrive from wise owl. You will lose your low range by dropping the R&P ratio. The stock engine doesn't have enough beans to pull hills.
      • blue bomber
        • Dec 2011
        • 48
        My rover has a V8 and a granny 4speed adapted to a stock t/case with"b" suffix gears.
        • SalemRover
          • Aug 2007
          • 310
          For the rear you can get a Salisbury. They aren't, knicknamed the flying anvil for nothing. I thought great basin rovers did an upgrade to stock rover diffs/ half shafts.
          • ArlowCT
            • Jul 2008
            • 238
            Thanks for all the input. I can't find much on the maxi drive half shafts, anyone have a link or know what happened to them?
            I have never had a problem with power out of my motor and run a overdrive right now. I would like to step up in tire size, axle strength and gain more traction (locker). But I don't want the overall final drive to change much and if it does i would like it lower. Anyone know how different the one tonne transfer case is? Can its low gears be installed into a suffix b case?
            • ArlowCT
              • Jul 2008
              • 238
              Blue bomber,
              Any chance you could share some info on those front cv's? And is your trucks wide stance all from changing the back spacing on some aftermarket wheels?
              Thanks!
              • blue bomber
                • Dec 2011
                • 48
                I will share. "B" suffix, denotes large pin case with a 2.88 low range rather than the 2.35 of a "C" and up suffix case. Does sound like much but it makes a difference. For example, in my case it takes my low range first gear from 55.65 to 1 to 68.20. With 350ft lbs of torque and 33's it won't stall !!The cvs are the same one that GBR sells as well as Ashcroft. There is a little trickery to make it work, but worth the effort. The wheels have 3 and 1/8th back spacing. 15x8
                • ArlowCT
                  • Jul 2008
                  • 238
                  Thanks again! I'm real interested in the cv's, time to fire up the old google machine and see what I can find under "cv's" and "trickery".
                  Cheers
                  • blue bomber
                    • Dec 2011
                    • 48
                    The cvs are early, stage one and 110. The spindles and swivel housing are modified to accept in cv and new inner shaft,in place of the universal. I'm considering composing a conversion guide for series LR's. I think it would be worth while endeavor.
                    • ArlowCT
                      • Jul 2008
                      • 238
                      I would love to know the whole story, if you put something together please add me to the list. Is it mainly a clearance issue and the housings just need to be opened up? Or is it one of those can of worm projects rivers tend to come with?
                      • ArlowCT
                        • Jul 2008
                        • 238
                        Ended up with a set of pegged ARB's wrapped in 4.71 gears and ROAM rear halfshafts. After a weekend at Rausch creek off-road park I could not be happier!
                        • I Leak Oil
                          • 1796
                          Nice! Now what about those front shafts? (if you find some cheap, let me in on it!)
