Vapour Lock
  • Boston
    • Feb 2010
    • 151
    #16
    Amazed that I seem to be hearing about VL more frequently this year than ever before.
    Weird.
    • bugeye88
      • Apr 2013
      • 167
      #17
      As for the ethanol in fuel; remember always use a ethanol neutralizing fuel additive and a lead substitute when filling up. Ethanol has MANY negative effects on our Landy's.
      Cheers,
      Rob
      • printjunky
        • 325
        #18
        Another option. I use this in my old boat motor ('77) and should probably remember to use it more in the Rover ('73).
        Pure-gas.org is the definitive web site listing stations that sell pure gasoline in the U.S. and Canada.
        • Opabob
          • Feb 2012
          • 40
          #19
          Reviving this thread. I was hoping someone could advise me on a couple of questions related to running an electric fuel pump. 1) it sounds like this Carter pump might be a good choice: Carter P60504 Electric Fuel Pump -- any thoughts pro or con? 2) I don't think anyone has mentioned installing an inertia cutoff switch. Is that just an obvious thing I should do? or would it just go off all the time because I have old springs and my truck rides like a coal cart? Any recommendations on which switch I should consider? Thanks for any thoughts on this!
          • bugeye88
            • Apr 2013
            • 167
            #20
            A couple of things to consider when installing an electric fuel pump. First it should operate at low pressure 1 1/2 to 3 PSI I believe. The Carter or any other good pump will do. I would mount it after the mechanical pump with a filter between the electric pump and the carb. I have a switch under the dash that I can turn on or off when I want. Usually I'll switch it on on initial start up to fill the float bowel for a quick start up, then switch it off for running. When it's hot I'll leave it on to prevent any vapor lock condition. As far as an inertia switch, it's probably overkill in my opinion with the above operation followed.
            Cheers,
            Rob
            68 series 2a "Bugeye"
            • mearstrae
              • Oct 2011
              • 592
              #21
              Here's another way of installing the Carter fuel pump. Mount the pump as close to the fuel tank as possible (these are "pusher" pumps and work best at the back) and install a large fuel filter between the tank and the pump. On my Series I also covered the pump and filter with a stainless steel box to protect them off-road. At the front: remove the mechanical pump and fabricate a block-off plate (why have two pumps?), also add a fuel pressure regulator (I think my last install used an Edelbrock regulator). This will get the fuel line away from the engine somewhat and help prevent vapor-lock. I also add a cut-off switch on the dash between the (fused) ignition feed wire and the pump, instead of an inertia switch (these are only 6# pressure not 40#). Some folks add a return line near the regulator, this really isn't needed as Carter pumps have an internal return if they are pumping too much fuel.
              '95 R.R.C. Lwb
              '76 Series III Hybrid 109
              '70 Rover 3500S
                • 383
                #22
                I've had inertia switches trip from water pressure in a car wash, so I don't think one would function well on a bumpy Series. Holley, Carter and others make a low oil pressure cutoff switch, that shuts off power to the electric fuel pump at 7 or so psig oil pressure. They hava a bypass on engine cranking so that the pump operates before building up oil pressure, and you would need to add all the right T fittings.
                • bugeye88
                  • Apr 2013
                  • 167
                  #23
                  The thing to remember if you are installing any electric pump as a "pusher" is to remove and block off the mechanical pump as described by mearstrae. The reason is if the diaphragm fails on the mechanical pump the electric will pump fuel into the crankcase.... Not Good! That's why in my case, where I'm using an electric on a part time basis, I mounted it after the mechanical as a "Puller" pump.
                  Cheers
                  Rob
                  • Opabob
                    • Feb 2012
                    • 40
                    #24
                    Thanks for the advice. It is good to get some opinions on this. My main problem is hard/no start with hot engine probably caused by vapor lock probably down around the pump. I also should have mentioned the previous owner installed a Weber carburetor.
                    • bugeye88
                      • Apr 2013
                      • 167
                      #25
                      I also run a Weber 34 ICT carb. I have found it to be an excellent set up. I've run Rochester's, which were a good carb also, but find the Weber has better milage and good running throughout the power band. As for the Vapor lock (if that's the real problem) the electric pump, wherever its placed, should cure that. The Weber is prone to clogging at the jet in the bottom of the float bowel, so use a good filter between the pump and the carb. Best of Luck on the fix.
                      Cheers
                      Rob
                        • 383
                        #26
                        A filter with a return line just before the carb helped on my 109. I had no problems while moving, but stopped in traffic or post engine shutoff I found the fuel boiling in the line underhood and in the carb bowl. The return on the filter allows a vent path back to the tank instead of the fuel in the carb and lines pushing into the intake manifold. It also helps by allowing a constant cooling flow thru the fuel line at slow speeds. I don't remember the part number, but I use a filter for a Chrysler product.
                        You would need to add a return line and fitting to the tank, if not already there.
                        • tmckeon88
                          • 142
                          #27
                          I had a similar problem of no restarting a hot engine in the summer, and I drilled a couple of holes through the inner surface of the gas filler cap- not entirely through, just through the inner lining, to allow air into the gas tank to replace the pumped fuel. Alternatively, if it vapor-locks you can try just loosening and re-tightening the gas cap. Never had a problem with it since. You might experiment with the gas cap trick before committing to having an aftermarket fuel pump installed.
                          Tom
                          Tom
                          1969 Series IIA 88"
                          • Opabob
                            • Feb 2012
                            • 40
                            #28
                            Thought I would update with a status. I tried all of the things suggested without results. So I went ahead and installed the electric fuel pump, adding in an aux fuse panel, dash switch and relay. So far no vapor luck; but it is not summer yet Also, the truck is running much better, so I am suspecting the mechanical pump was probably struggling. I did not want to replace the mechanical pump not knowing if it was the problem, but in retrospect, I suppose I could have got a fuel pressure gauge and checked it. Thanks to all for your suggestions.
