I'm looking to install an aftermarket power steering system to my vehicle so my wife can drive it more easily. The only one I can find is called "EasyDrive" which is currently offered by us auto performance in Florida. Does anyone have experience with this unit? Are there any other options out there? Thanks for any info on this subject.
power steering aftermarket options?
Tags: None
If you have an aversion to Japanese parts on your rover. The scout II or RR p38 boxes are an easier swap. The scout box sector shaft is he same spline as a Adwest/rover box. No messing with odd tie rods. As stated above. It's a fair amount of work, but totally worth it. Check out this link. Its pretty useful.
http://www.expeditionlandrover.info/PowerSteering.htm
If it were me and I wanted the least intrusive easiest to install and arguably most powerful system I would opt for the hystee hydraulic one. The electric assist needs a whopping 60 amps, which is a huge draw on the battery and the (wimpy) charging system of the Landy.
I would only recommend the Range Rover conversion if it were part of a larger refurbishment plan. It requires engine, frame, body and steering column modification as well as new steering rod. Only for advanced DIY or specialist shop installation.Comment
There's also the IH Scout (I think) conversion. There's a youtube video on one that I can't seem to find at the moment.Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZFComment
I don't know Bill...That Heystee kit would be the last thing I'd want to install. To me it looks overly complicated and too vulnerable to damage and the elements. Ease of install is a plus but I'd just keep the system stock before I put that kit on. My 2 cents.Jason
