Removing Railco Bush
  • 1968seriesIIA
    • Jan 2012
    • 19
    Anyone have any tips on removing a Railco Bush from a swivel ball? Mine seems pretty stuck and I don't want to damage the swivel ball. Also I assume I may have trouble putting the new one in so any tips for that as well would be greatly appreciated.
  • SalemRover
    • Aug 2007
    • 310
    I brought mine to a engine rebuild shop, 5 minute job with a 40 ton press.
    • 1968seriesIIA
      • Jan 2012
      • 19
      I was thinking I may have to do something like this thanks for the suggestion.
        Being an odd shape it's difficult to hold and support if you try to tap it in with a block of wood and hammer (or similar). A press really does make short work of it and is safest for those expensive parts. Short money to do it vs. making a mistake with the BFH.
        • Contractor
          • Jan 2013
          • 127
          I just did this as well, good advice above.
          I took mine to NAPA ( some have a machine shop) and I think they charged me $20 or so and it took about 20 minutes.
          1969 IIA - Tan
          1969 IIA - Blue
          • o2batsea
            • 1199
            Removal with a long punch and a big hammer up thru bottom. Install by freezing. With bore lightly greased should tap in with a wooden or plastic mallet. Just keep an eye on the alignment. If it gets off kilter just work the high side til it's back in line.
            • SalemRover
              • Aug 2007
              • 310
              I had removal and refit done by the way. Bring the new railco with you, it also cost me 20$ about 7 years ago.
