Facet pump not priming
  • rickv100
    • Aug 2010
    • 143
    After having problems with 2 mechanical fuel pumps I installed a Facet cube pump. I installed it on the inner frame rail forward of the passenger side fuel tank. I have an Ex-Mod Series 3 with the saddle tanks. I ran a line from the passenger fuel tank to the pump bypassing the fuel tap to lessen possible leak points.
    I made sure the lines are clamped tight and the cube pump is mounted at a 45 degree angle. The fuel tank has about 4 gallons of gas in it. I have blown out the fuel pickup and the lines are new 5/16 ethanol proof rubber lines.
    I cannot get the pump to prime. I have let it run for about 2 minutes at a clip several times and it is not picking up fuel.
    I have double and triple checked my clamps to make sure there are no leaks. Anything else I can try?
    Thanks,
    Rick
    73 xMOD S3 109
    52 M37
  • mearstrae
    • Oct 2011
    • 592
    I know this may sound stupid but... Is it wired correctly? Are the hoses on the correct ports (In - Out)? Stranger things have happened.
    '95 R.R.C. Lwb
    '76 Series III Hybrid 109
    '70 Rover 3500S
    • bugeye88
      • Apr 2013
      • 167
      Rick,
      I also have a facet pump, although mine is placed after the mechanical pump and used to prime the carb or use in case the mechanical pump fails. I place it after the mechanical pump to avoid pumping gas past a failed mechanical pump into the crankcase. I have used the facet pump on several applications and never had one fail or not pump. They are solid state and do not have a diaphragm, so if it sounds like it is working it should pump. I would look at the pick up tube for the tank you are drawing from first. I have seen a pick up tube that is partially rotted away and does not go to the bottom of the tank. This is often not noticed in two tank applications if this is in the tank that feeds the other tank. Pull off the plate with the pick up in it and check that it goes clear to the bottom of the tank. Or you could pull the fuel tank line and put it in fuel in a container and try.
      KTF
      Rob
      • dunerunner
        • May 2008
        • 110
        Re-check the direction of flow. Just a thought...
        '94 D-90, '59 SII 109 Regular
        • giftshopduane
          • Feb 2009
          • 103
          Facet pumps are junk, as are any mechanical/solenoid type pump. Go with a Carter rotary vane instead, no more than 6-8psi..
          • mearstrae
            • Oct 2011
            • 592
            LOL...What Duane said.... Used to have Facet (Think: "Just as good as Lucas.") pumps on my 3500S and my Series III, and both have Carters on now, that have been in use for years. Ditch the mechanical.
            '95 R.R.C. Lwb
            '70 Rover 3500S
            • blue bomber
              • Dec 2011
              • 48
              Use the carter p60504. Quiet and low pressure 2-4 psi and 30gph. I run this with my 5.7 liter engine. No problem supplying enough fuel. Made in USA, if that is important to you. Even a "crappy" new pump should draw fuel. Check the solder joints on the pick up tube. I used relays on all non original electrical items, fuel pump, hella H4 head lamps , etc. By doing this it keeps the load off the low current switching devices. I can honestly say I have had zero electrical issues since my rebuild. Just my .02
              Cheers, Matthew.
              • rickv100
                • Aug 2010
                • 143
                Just an update. I read on another forum to prime the pump using a syringe to fill the pickup hose and disconnecting the output side so it was not pushing air. Once the facet pump was primed it developed suction.
                Rick
                73 xMOD S3 109
                52 M37
                • o2batsea
                  • 1199
                  Or, you can just suck on the business end of the hose that goes to the carb until you begin to feel a slight push of air from the hose (pump running). That's your signal to get the hose out of your mouth before you get a gulp of gasoline.
