Transfer case mounts
Word from RN is they are the same. Knowing Rover they used to come in a different box at a different price, but were identical otherwise.'67 109 NADA #413 - rebuilding w/ TDI & galvy chassis.Comment
The engine and transfercase rubber mounts are the same. You can use either the petrol or the diesel versions. I prefer the stronger diesel ones.-
Originally they were different compounds, more resilient on the transfer box.
Teriann is correct though, most folks use the more heavy duty diesel version.
2pLes Parker
I have the diesel engine mounts in hand and am trying to fit the transfer case to my new chassis, and it doesn't look quite right somehow. There seems to be about a 20-30 degree difference between the brackets coming off the t-case and the mounts on the cross member. Is there an extra piece that goes in between, or is my new chassis a little off, or is it just the way things are? If anybody had a photo lying around of the standard mount in situ that might help clear things up for me. This is a 109" 6-cylinder chassis if it makes a difference.'67 109 NADA #413 - rebuilding w/ TDI & galvy chassis.Comment
Nevermind - seems I'm missing these little guys:
I was a little scared they'd be unobtainium. Not sure how they escaped their baggie, but I'll probably find them in a dark corner the day after I take this thing for it's first spin.'67 109 NADA #413 - rebuilding w/ TDI & galvy chassis.Comment
