True size of 235/85-16 KM2's
  • ArlowCT
    • Jul 2008
    • 238
    Does anyone know the true size (not what BFG says they are) of the 235/85-16 KM2 tires? I just want to make sure they measure out to be 32+" tall. Thanks!
  • mearstrae
    • Oct 2011
    • 592
    One site says 32" another 31.73". So, they seem to be about 32", but not taller. Maybe go to a 245, that'd be about 32.5".
    '95 R.R.C. Lwb
    '76 Series III Hybrid 109
    '70 Rover 3500S
    • Contractor
      • Jan 2013
      • 127
      I'm running 255/85/16 in the same tire and measure out to 33" x 10.5"......or pretty dang close.
      1969 IIA - Tan
      1969 IIA - Blue
      • ArlowCT
        • Jul 2008
        • 238
        Thanks for the response. Are you running stock rims? How is the turning radius? How flexible is your suspension?
        I'm running 245/75-16 AT's right now with two leaf front and rear springs. I like how much travel I have but the rear tires do rub at full flex in the rear. I also like the tighter turning radius and quicker acceleration but I really miss the ground clearance. My new shoes will be mounted on different rims that should push them out about a inch more so that should help with turning radius. Having trouble deciding between the skinny 32's and the little wider 33's!
        • Contractor
          • Jan 2013
          • 127
          They are not stock rims, but I honestly don't know what they came off of. The turning radius is fine, but then again it's an 88" truck. I have 2 leaf Rock Mountain Parabolics and the truck rides great. Perhaps if I hit a big hole off road I might rub, but I have not experienced any yet.
          Here are some pictures I took:
          1969 IIA - Tan
          1969 IIA - Blue
          • rwollschlager
            • Sep 2007
            • 583
            I'm running 33x10.5x15 BFG Km2 (the 15" equivalent to the 255/85), I went with this size because they were ~$30 cheaper per tire than the 255. They do rub slightly at full articulation in the rear, nothing noticeable up front. I would get this size again, no complaints thus far. You should get your truck done and bring it to muddy chef to test it all out!!
            -Rob
            oh, and they work quite well on the trails:
            72 SIII 88
            67 SIIA 109
            82 SIII Stage 1 V8
            • stomper
              • Apr 2007
              • 889
              I hate to say it, but after looking at Contractor's truck, it almost makes me want to put a set of jackman spoker rims on my truck. it really gives it a 1980's beach runner look. I'm pretty sure I know where to find some.
              • Contractor
                • Jan 2013
                • 127
                Yep, you can't get the 33" x 10.5" size in a 16" wheel, so 255 is your only option. The only disadvantage to the 16" wheel and KM2's (or just about any other manufacturer) is you are stuck with a load range E tire in that size. Surprisingly these ride really well, but I have had E tires that ride like crapola.
                I like those spoker rims, they would look pretty nice........especially in limestone.
                1969 IIA - Tan
                1969 IIA - Blue
