I'm having one of my 2.6L's completely redone, a question has developed on the dimension for the main journal. Both the green bible and the NADA supplement report the journal is 2.625 inches, however when we put a micrometer on it, it is 2.5 inches, there is no wear or slop. Has anyone encountered this difference? Any insight / advice would be appreciated.
'67 NADA engine question
On page 51 of the NADA supplement it gives the "nominal" diameter. To us the key word is nominal in the sense of "approximate ". Just like a 2x4 is a nominal dimension.Comment
1/8" That's a big difference! Make sure that spec is for the 6 cylinder first off. If so, perhaps it has already had some major machining in its past life?Jason
Good point about the right engine. 2.25 is 2.5"
For 2.6
Page 12-43
Journal diameter 2.6254 - 0.0005
Regrind permissible by .010 increments to 2.584Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZFComment
