My '73 109 (w/Salisbury) has 10 spline inners and 24 spilne outers both front and back and use off-the-shelf 24 spline driven members on the hubs.
For some reason I was thinking the Salisbury was 23 spline but that may be the 101 salisburys? Not sure! Forgot to ask about the drive flanges and was hoping someone here would have the quick answer. I know my stock ones are 10 spline and the stock defender 24 spline only have five mounting bolts not six like the series.
The Salisbury 24 splines use 6-bolt drive flanges and fit both the rear Salisbury hubs and the front Rover-type hubs. I've had to swap a good front out with a worn-out rear to get me home on more than one occasion:
Stock drive flanges. But procure spares as they do strip out from time to time. I tore apart an entire rear axle before I figured out it was the drive flange.
What were you doing when the flange let go? What engine, tire size are you running?
If its anything like when I brake something you were shifting into second pulling away from a stop sign! So far I have broken very little off road but a lot has let go on road!
Geezzz guys! Sometimes I wonder
Your SIII 109 has a front axle assembly that has a 24 spline outer axle and a 10 spline inner axle. Your rear Salisbury is 24 spline at both ends. This gives you the same 24 spline drive flanges all the way around.
The factory 24 spline drive flanges are out of a relatively soft steel. When the wear there is enough of a spline gap that you hear a very audible clunk when you come to a stop. This is long before the flange wears to the point where it might break. This is often referred to as the Salisbury clunk and is your signal that it is time to replace drive flanges.
There is a hard steel 24 spline drive flange available aftermarket. They are shaped a little differently than the stock one, have a different finish and a screw on dust cap.
Reason: Removed bad information aftermarket drive flange
That's what I would have thought too. Not mine. 10 inner, 24 outer. At least they were the last 2 times I had them out, but now you've bumped my confidence level on this down to 95% so I've got to swing out and pull an axle shaft just to re-verify this.
I've never heard of a Salisbury with a 10 spline end. Nor have I seen one in a catalogue, including a LR parts catalogue. There is a version of the Rover front axle assembly that has a 24 spline outer shaft and a 10 spline inner shaft. This was so they could have 24 spline drive flanges all around. It may have happened but I have yet to meet anyone who as broken the short outer shaft of a front axle unless it was part of a U joint or stub axle failure.
6 bolts, some flange surface cleaning, a little RTV and you can check your rears in just a few minutes. 28 lb ft torque then you replace the fixing bolts.
TeriAnn: I thought I had seen some heavy duty flanges but that pic shows 5 mounting holes. The series have six. Is this just a case of the wrong picture for the part? Thanks for the info.
(Update). Just talked to RN and they confirmed PLH009 is for the newer axles with five bolt drive flanges. I'm having a hard time coming up with a source for the six bolt ones.
