I have a 99 Disco and a Series III 109
  • moodhair
    • Aug 2011
    • 48
    If you had the two vehicles above and the Disco was going to be parted out, would there be anything from the disco that you could use in Series???
  • antichrist
    • Mar 2009
    • 272
    With enough work pretty much anything could be used.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
    • ArlowCT
      • Jul 2008
      • 238
      The money from it to buy more series parts
      • I Leak Oil
        • 1796
        Why ruin a perfectly good series truck?!
        • o2batsea
          • 1199
          I guess the real question is, "is there anything that I can swap over from a disco that would add value to a Series 3?" I think that answer is no.
          • moodhair
            • Aug 2011
            • 48
            Decided to keep the Disco and get a new transmission and prop-shaft for it. I getting the transmission out and back in without the help of a lift is almost impossible.
