To all 109 5 door NADA owners
  • Paul and Judson
    • Sep 2010
    • 110
    If you have a reasonably stock model of one of the 811 examples, could you please send me a picture of the front floor. I am especially interested in the position of the shift lever in the hole in the transmission tunnel cover so if you have a boot or a floor cover, could you remove it before the picture. If you cannot take a picture, could you tell me where the shift lever is in the hole (center, to the left or right of center)? Thank you very much for your efforts.
    current owner of #524
  • gwmaxhunter
    • Jul 2013
    • 47
    Hi whats a 811? i can send pics of a 109 with a 6 cyl? does that help?
    • ArlowCT
      • Jul 2008
      • 238
      I think they may have made 811 of these trucks.
      • Paul and Judson
        • Sep 2010
        • 110
        Thank you both for your replies.
        ArlowCT is correct there were 811 of these trucks made in 1967. They had a modified 6 cyl engine with a Weslake head. There were other differences from a basic 2a with a 6 cyl engine.
        gwmaxhunter if your 109 is a 5 door station wagon with a 6 cyl and is a 2a than pictures of the uncovered floor and transmission would help. Thank you for the offer.
        Any other NADA owners it there? There is a registry of existing owners and trucks on the forum so maybe one of the registry members can help
        • SalemRover
          • Aug 2007
          • 310
          My shift lever sat to one side on the transmission tunnel cover. That was due to a failed transmission mount though. If there is a rubber boot that goes over the shifter ball end then you can assume it needs to be center.
          • lrover109
            • 40
            Did you still need the pic? Mine is fairly standard with the addition of an overdrive.
            • Paul and Judson
              • Sep 2010
              • 110
              Thank you. If you have a NADA 5 door 109 with a 6 cylinder engine a picture of the uncovered front floor would be most helpful
              • gwmaxhunter
                • Jul 2013
                • 47
ID:	168169Click image for larger version
ID:	168170Click image for larger version
ID:	168171Hi, ok now where do i find the picture thing....?.....Click image for larger version
ID:	168166Click image for larger version
ID:	168167Click image for larger version
ID:	168168 i hope this helps i can take any pic you want me to just let me know........the 10 inch pic is my 4cyl 109
