When I tried to install Warn M11 hub, the outermost "half" with 6 bolts wouldn't slide up tight to the inner "half" by about 1/4". Like the end of the axle is interfering? Am I being really stupid? Also, how much in-and-out play is correct for the front axle when the castle nut is off? Many thanks.
Warn Hub Installation Problem?
grind off end of axle to fit
that is the secretWhen I tried to install Warn M11 hub, the outermost "half" with 6 bolts wouldn't slide up tight to the inner "half" by about 1/4". Like the end of the axle is interfering? Am I being really stupid? Also, how much in-and-out play is correct for the front axle when the castle nut is off? Many thanks.1968 battlefield ambulance/camper
1963 Unimog Radio box
1995 LWB RR -
You'll notice a nub on the end of the stub shaft that is used when they machine the shaft. You will need to remove that with a grinder or your favorite tool of choice. That contacts the ramp mechanism inside the hub causing the gap you have. Just keep removing a little at a time until it fits and you can easily turn the selector by hand.Jason
