Gas not getting to carb?
  • stomper
    • Apr 2007
    • 889
    #16
    Yeah, I'm getting ahead of myself. I just want this week to be over!
    • Contractor
      • Jan 2013
      • 127
      #17
      Originally posted by I Leak Oil
      TAKE THE LINE OFF THE CARB AND MAKE SURE YOU'RE NOT GETTING FUEL UP THERE. WORK YOUR WAY BACK.....SORRY FOR SHOUTING BUT MY GOD, THIS ISN'T ROCKET SCIENCE!
      ....there....I feel better now.
      lol
      I had the same thing typed yesterday and decided to hit delete.
      1969 IIA - Tan
      1969 IIA - Blue
      • I Leak Oil
        • 1796
        #18
        Good or bad I seem to forget where my delete key is these days. Nothing personal.
        • ivan
          • Aug 2009
          • 47
          #19
          THANKS
          • pyounts
            • Jul 2008
            • 25
            #20
            Having same issue as original post. Ran it out of gas and found their was no fuel to carb. Took line off going to fuel pump and gas gets to fuel pump. Cleaned bowl and then took top off of fuel pump. Really looks pretty clean and I didn't find any trash. Everything in fuel pump looks ok. Put it back together and still nothing. Did priming lever a bunch but it is not sucking anything into the sediment bowl.
            Any ideas?
            • Contractor
              • Jan 2013
              • 127
              #21
              Any ideas?
              If you have no fuel to the carb you can work backwards to a fuel filter (assuming you have one). If it's clean and still no fuel to the carb, continue to work backwards to the fuel pump. Clean the glass bowl and re-seat in the rubber gasket..........if it does not seat perfect you are going to get an air leak and it's not going to prime. While it's a pain in the ass the best way to ensure a tight seal is to pull the pump off the block and re-seat the bowl on the workbench, then re-install the pump.
              The little hand prime sucks.......keep turning the motor over with the key to get it to prime.
              If you still get nothing you can go backwards yet again and check the fuel pickup tube and screen. If your tank is full of rust, dirt or water drain it.....clean it.....change the filter and try again.
              There are only a few things that are going to screw you up between the tank and the carb:
              - Pickup tube/Filter
              - Fuel Pump
              - Paper inline filter
              Process of elimination, around six beers, philips head screw driver and 1/2" open ended wrench should cure what ails you.
              1969 IIA - Tan
              1969 IIA - Blue
              • pyounts
                • Jul 2008
                • 25
                #22
                Thanks! I've really done all of that. Gas gets to the fuel pump but does not come out. Do you have to prime it with gas to get it to start pumping?
                I saw something in an earlier post about using a syringe.
                • I Leak Oil
                  • 1796
                  #23
                  Perhaps the diaphram has a leak or the out check valve is stuck closed.
                  • pyounts
                    • Jul 2008
                    • 25
                    #24
                    I read on another post (maybe a joke) to try and suck gas into the fuel pump. We'll I tried but from the output end and it is closed or stopped up.
                    • ArlowCT
                      • Jul 2008
                      • 238
                      #25
                      Any chance the one way check valves got flipped when you had the pump apart. There should be two in it, one in each side of the diaphragm.
                      • pyounts
                        • Jul 2008
                        • 25
                        #26
                        I took the top off of the fuel pump, but didn't see any loose parts that could have been put back in wrong.
                        • I Leak Oil
                          • 1796
                          #27
                          If you put a fresh hose on the intake port and run that into a jar a fuel will it pump then? If not it's your pump. If so, keep looking at the lines, pickup tube and tank.
                            #28
                            3 pages/24 posts...well, 25 now...and we still haven't identified the exact point at which the fuel stops flowing in a system that consists of a grand total of 4-components (one of which is "fuel hose")?
                            Good thing it's not ignition-related!
                            • I Leak Oil
                              • 1796
                              #29
                              Hey, I'm supposed to be the bad cop in the good cop\bad cop routine!
                                #30
                                Oops...Sorry Jason--Bit of a misunderstanding, I'm afraid. Let me go behind you where I will struggle to restrain you while you attempt to break free of my bonds and go berzerk.
