I installed my door tops last night and it appears they don't angle in enough to conform to the seals as you can see from the photos. The driver's side isn't as bad but still noticable. I am using new seals between the door and door top that I got from RovahFarm. Varying the tightness of the nuts securing the door tops doesn't seem to change the angle. There doesn't appear to be any real adjustment of this angle. The door bottoms are aligned properly in relation to the tub.
I can think of two ways to correct this. 1) Bend the door top studs slightly. This seems fraught with danger (I imagine snapping the studs off from whatever is holding them inside the door tops). 2) Shim the outside edge of the seal.
Any suggestions?
Any suggestions?
