Stalling
  • moodhair
    • Aug 2011
    • 48
    Stalling
    Last Friday I took the day off so I could go and get the Rover registered and tagged in the state of Florida. I eventually made it to the Department of Motor Vehicles only after stalling out once on the way. Call to AAA revealed that it wasn’t the battery but more than likely the fuel pump or the operator.
    On the way home I stalled out two more times (both on busy streets) and was pushed into a gas station the first time and pulled by a guy with a F350 and a two rope the 2nd time. I called AAA again and had the truck towed home.
    The next day I tempted fate again and took the dogs to the dog park with my wife no more than 2 miles away. On the way back – it stalled and I was towed again by a good Samaritan with an F550 this time ($167 to fill up per the owner) to a local parking lot. My wife took the dogs and started the 2 mile walk home leaving me in the parking lolt. Twenty minutes later starts up it starts up again and I nurse it down the street trying not to stop and pick up my wife on the side of the road with the dogs and pray that I don’t stall out on the way home.
    I think I’m the culprit – I pull the choke out all the way to get the truck started and generally push it in half way after I’ve been down the road a few minutes. Sometimes I make the mistake of pushing it in to far and I think that is what is calling the stalling.
    Is that a logical assumption?
    Also, my Max speed is 40mph period – is it worth rebuilding the weber carb to see if that helps? Also I may have screwed up by putting too much oil in the air filter. I mistakenly put oil in the middle part of the bottom part of the filter not just in the outside area. Would this also be causing a problem? Any thoughts appreciated.
  • LaneRover
    • 1743
    You should be able to push the choke all the way in once the truck is warmed up without it being a problem.
    Max speed should not be 40 mph. I think that most Rover owners will tell you that their truck is happiest at 40 - 45 but will go 65 if pushed.
    My brother once had an issue with his mechanical fuel pump being completely gummed up to the point that it would barely pump - it would pump just fine for idling and starting off down the road but not enough to drive very far. I would see how well the pump is pumping.
    Also when this stalling happens I would also see what your spark is like. Folks have had issues with their coil/condensor not working when it is hot.
    • moodhair
      • Aug 2011
      • 48
      Originally posted by LaneRover
      You should be able to push the choke all the way in once the truck is warmed up without it being a problem. (Well that solves one of my concerns..._)
      Max speed should not be 40 mph. I think that most Rover owners will tell you that their truck is happiest at 40 - 45 but will go 65 if pushed. (Good to know..)
      All good points - anyone know where I can find a replacement fuel pump cheap? Don't have the biggest budget and have a lot to do. The spark plugs and distributor are brand new and put in by a land rover mechanic in the UK before it was shipped over - so that shouldn't be the issue but I will check them this weekend. I must admit I wish there was a tachometer on this think so I could see the RPMs and figure out what the RPMs should be when it is at idle properly.
      Thanks for the response.
      • cedryck
        • Sep 2010
        • 836
        fuel pumps for this truck are cheap, check out hosts, about 30 or so around there,
        • bugeye88
          • Apr 2013
          • 167
          Could be lots of things, all of which are probably limiting fuel to the engine. Carb possibly with partially block jets, fuel filter or fuel line blocked, bad fuel pump as mentioned. Also take a look at the fuel pick up in the tank for blockage. As for the air cleaner, try running it without the filter hooked up and see if that makes any difference.
          Cheers and KTF,
          Rob
          • sleam
            • May 2010
            • 104
            I'd suggest a simple tune up to start, check the air filter, points, all of that. When I brought mine home last year it would stall out because of vapor lock. Theres a bunch of threads here for that. It should go faster even if happiest at 45 like mine. Check/ replace the fuel filter too.
            1959 SII sold
            1972 SIII RHD 88" (current project!)
            • LaneRover
              • 1743
              You could also wire up a temporary electric fuel pump - you can get one of those pretty cheap - though make sure it isn't high pressure.
              • osajaj
                • Mar 2010
                • 103
                I would always start simple, my condenser was bad and had caused stalling/dying.
                1996 Discovery SE7 5spd -SOLD
                1962 Series 2a 88"
                • LaneRover
                  • 1743
                  I also agree with Sleam - do a tuneup before you dive into additional parts and costs.
                  • siii8873
                    • 1013
                    was the gas cap repaced? I replaced the cap on my SIII and started having the same symptoms. The newer caps are sealed and do not allow air into the tank. Next time it happens remove your cap and see if it under vacuum, you will hear it.
                    THING 1 - 1973 88 SIII - SOLD
                    THING 5 - 1958 109 PU
                    THING 6 - 1954 86" HT
                    • moodhair
                      • Aug 2011
                      • 48
                      The culprit too much oil in the air filter!!!!!!!!!!!!! Now I need a new radiator. Any suggestions on alloy vs original?
                      • bugeye88
                        • Apr 2013
                        • 167
                        Too much oil in the air filter.... change to a K+N! Radiator relation to this????? If you are replacing the radiator Stock is fine, consider a thermostatic fan along with it.
                        Rob
                        • Faulkner34
                          • Jul 2013
                          • 25
                          Moodhair - I have recently experienced very similar issues on my SIII. I read your post and a light bulb went off. The issue only started after I took the air cleaner apart, cleaned it, and refilled it with oil (including the inner circle at the base of the casing). How did you determine your issue was the air filter? Also, how do you know you now need a new radiator? Funny, I thought the air cleaner would be the most basic foolproof work I would do on my Rover but I (ie. fool) may have proved it otherwise
                          • moodhair
                            • Aug 2011
                            • 48
                            Stalling
                            I made the mistake of putting oil in the middle of the air filter as well - it just needs to go on the outside of the round vessel in the filter. Once it was cleaned out it works fine - no more stalling.
                            The radiatir was a garage telling me I needed one, which was odd considering mine isn't leaking anywhere. I picked up a bottle of "stop Leak" the copper version and put half in the radiator per the instructions just in case there is a leak somewhere,=. So far no issues and I drove it farther last week (20+ miles) with no issues. Still can't get it to go past 50 though.
                            • Revtor
                              • Apr 2012
                              • 265
                              50 is pretty good with no overdrive, but it should go faster (In my experience 1969 88") what size tires are you running? Your engine might just be very tired and down on compression/power. could be a lot of things. gotta be methodical, go down the list and check one thing at a time.
                              ---- 1969 Bugeye ----
                              ---- 1962 Dormobile ----
