Gearbox/Transfer Case/Overdrive service recommendations SIIa
  • mrmurray
    • Oct 2013
    • 26
    Hello! I have a stock 1967 Series IIa with 4-speed gearbox/transfer case and overdrive. These units are currently out of the vehicle while I am rebuilding the engine. I plan to re-seal these items and am looking for advice on any maintenance I should do while the drivetrain is out of the truck? I intend to keep the vehicle stock.
    At this time, I plan to replace the driveline u-joints, any accessible shaft seals, and housing gaskets as required to slow down the leaks (and it looks like everything leaks!)
    I also plan to replace the clutch assy. and turn the flywheel.
    If there are any other maintenance items you would recommend, please let me know.
    Thanks!
    Mike in Portland
  • east high
    • Jan 2008
    • 337
    Get some of this:
    There are a few lock washers and cotter pins you'll need to replace if you intend on getting to all the seals and gaskets, and count on using a few Whitworth tools if you want things all the way apart.
    '67 sIIa 88
