After searching through what seems like 759 postings on this forum concerning idle problems, I'm still stumped. My '69 engine with Rochester carb in the IIa idles way too high and I can't get it to slow down. I've tried screwing in the idle screw at the back of the carb and it doesn't appear to have any effect, even when screwed all the way in. I've fidgeted with the carb, the ignition timing and the dizzy and I can certainly make it worse but, I can't find any combination that makes it any better.
Because the idle screw isn't having any effect, I figured I was getting air in around one/all of the gaskets at the various carb and/or manifold interfaces. I've sprayed carb cleaner all around there while it's running but, I guess because it's running so high, I don't seem to notice any appreciable difference, as if there was a leak.
It seems to run fine except when I'm shifting and or sitting at idle at a light. There's no backfiring and it cuts off great when I turn the key off. I've replaced the ignition coil and have a Pertronix conversion kit on order. It should be here any day now. I'm hoping that helps at least a little. If not, I understand it's still an upgrade to the points so all's not lost.
I guess I'm contributing to post 760 on this topic but. I can't figure it out. Any suggestions or usual suspects?
Thanks.
Thanks.
