Series carrier bearing question
  • LR Max
    • Feb 2010
    • 315
    Hi All,
    So I am replacing my carrier bearings in my salisbury rear axle. I looked up and as mentioned on Terri Anns website (not trying to throw anyone under the bus here), the bearings needed are a 382A and a 387A.
    Sounds good.
    So I pull the carrier. The races have 382S stamped on them. Huh.
    So what is the difference? I guess my biggest concern is I already ordered the A stuff, but I might need the S stuff?
    Is there a difference? If there is, what is it? My current thought process is that these are probably the bearings that came in the truck 40 years ago. So along the way someone said, "I have a better idea" and then they swapped over to the A bearings. If that is the case, then sounds good as long as everything fits up fine.
    I'm looking for "There is no difference Max. Put em on and keep rovering."
    Max, according to the Timken website the diameter of both cups are the same at 3.8125 inches. However the 382A series cup is .6250 wide while the 382S series cup is .7982 wide.
    If you use the A series you may need a crap load of shim.
    • LR Max
      • Feb 2010
      • 315
      Crap...
      • antichrist
        • Mar 2009
        • 272
        I don't know about the Salisburys, but I the the Rover diffs had some variation in the bearings. Have you measured your old one? I always remove and inspect before ordering if at all possible. I learned the hard way.
        Tom Rowe
        62 88 reg
        67 NADA x2
        95 D1 - R380
        95 D90 - R380
        97 D1 - ZF
          I forgot. Max you have a detroit in the back. That may be why you require a different cup. Like Tom said, get in there and a check it.
            Nevermind, I think the detroit only replaces the internals and not the whole carrier on a salisbury.
            • TeriAnn
              • 1087
              All I had to go by were the numbers on the boxes when I had my Salisbury professionally rebuilt in 1996. The 'A' was what they put in my Salisbury.
              • mearstrae
                • Oct 2011
                • 592
                It's probably no help at all, but the Dana/Spicer 60 (I think that's what's meant by Detroit) uses the "A" series in MOST of theirs. But the correct info should be out there, possibly from our hosts.
                '95 R.R.C. Lwb
                '76 Series III Hybrid 109
                '70 Rover 3500S
                  Max has a Detroit locking diff instead of the stock open diff. Has nothing to do with being a Dana style.
                  Hope Max reports back with what he finds.
