Tex-Magna lite wiring question
  • DGG
    • 304
    I'm rebuilding my Tex Magna Lite flasher. While bench testing the unit, I couldn't get the light on the unit to come on and flash unless I hooked it directly to the green/red wire, or the green/white wire. then it would come on and flash along with the turn signal light. According to my wiring diagram, the black/red wire powers the bulb from the P post on the Lucas three post flasher unit. Could I have a bad flasher unit?
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
  • DGG
    • 304
    I think I have a bad flasher. With the indicator flashing the turn signal, there is no power to the P post on the flasher unit. Confirmed with a test light. What are my flasher unit options? Thank you.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
      • 400
      The #550 three prong flasher should work just fine. The NAPA part number is NF 550, but a similar part should be available from any of the good auto parts places. The three prong flashers were used in a number of early applications including the hazard flashers on late '60s early '70 MGs and Triumphs and turn signals on TR3s and early TR4s.
      '02 D2 SE Kalahari
      '02 D2 SD
      '97 RR 4.6 HSE Vitesse
      '80 SIII 109
      '75 SIII 88 V8
      '68 SIIA 109 V8
      • DGG
        • 304
        Thanks. I'll check NAPA tomorrow.
        Doug
        61 Series II 109 SW
        95 RR County LWB
        06 Range Rover
        98 Discovery LE
        • DGG
          • 304
          Where is the flasher unit typically installed on the series?
          Doug
          61 Series II 109 SW
          95 RR County LWB
          06 Range Rover
          98 Discovery LE
          • fliptscript
            • Jul 2008
            • 12
            On a IIA it's behind the instrument panel where the gauges are. It should be mounted on the firewall.
            1967 IIA 109 Regular RHD
            1993 Range Rover LWB (gone, thankfully)
            1969 IIA 88 Bugeye (gone, unfortunately)
            • DGG
              • 304
              Thanks.
              Doug
              61 Series II 109 SW
              95 RR County LWB
              06 Range Rover
              98 Discovery LE
