Anyone looking for a Plow for a series III 88 or 109? Vermont
  • SweetPear
    • Aug 2007
    • 21
    I am acquiring a 1973 Series III 88 from a family member in Vermont and currently has a plow attached (meyers hydraulic I think). This will be removed prior to me bringing it back home to NC as I plan on fixing it up and then eventually bringing it to my house in the Spanish Virgin Islands to use as an island vehicle. Not much use for a plow in the islands unless you plan on pushing sand around. Vehicle is located approx. 30 minutes from Rovers North headquarters in Northern Vermont. Would be willing to swap complete plow setup for any misc. Series III parts that I might need for restification of the old girl. Let me know if you have interest as I might be moving the vehicle in the next week or so. Get ready for the snow....It happens every year whether you like it or not.
    Here are some pictures of the plow and the attachment to the frame.
    Chad Pearson
  • LH Drive
    • 253
    Your 73 series 3 has an early 69-71 series llA metal grill and badge. If the interior dash is also metal it may not be a 73 at all. Not bad as most think thats the last real series trucks made before they made them fancy by adding plastic. They should have left the plastic stuff for the Range Rovers.
    1972 NAS Series 88 SW
    • SweetPear
      • Aug 2007
      • 21
      Hmmmm....thought it was a Series III...you decide
      Take a look at this dash assembly and tell me if it is a 73 series III or an earlier IIA.... Now you have me confused. Either way...I am going to get the vehicle and would love to give the plow to someone in need before it goes in the scrap metal bin.
      Thanks
      • LH Drive
        • 253
        Yeah thats a Series 3 dash. My Rover also came with the llA metal grill and badge. I found a used S3 plastic grill on e-bay for .99 cents a while back. I also like the look of the llA grill and I switch grills now and then to keep the public wondering. Kinda like getting a hair cut and see if anyone will notice.
        • Leslie
          • 613
          Don't be confused: you're right, you have a SIII. Not only by the dash, but if you look at where the windscreen hinges are, it's the squared tower (SIII-only), all IIa's had a vertical plate, and Defenders have ones that bolt onto the windscreen and the bulkhead directly, w/o the tower. That's the easiest way to tell from the outside, because all the other bits are interchangable (wings, grille, bonnets, etc.). It's easy to make a III (superficially) look like a Defender, or a IIa, but those hinge mounts are pretty much fixed w/o a LOT more work....
          -L
          '72 SIII SW 88"
          '60 SII 88" RHD
          • Leslie
            • 613
            Doh! Simultaneous posting.
            Anyway, yep.... I've got a IIa grill on my III, too.... (the III grill is hanging in the garage).
            As far as the plow... it's cool, I'd like to have it for the novelty of it, but, I don't need it, don't have parts to trade, isn't worth coming up after.... Good luck w/ it, tho'... someone in that neck of the woods is possibly looking for such....
            FWIW...
            -L
            '72 SIII SW 88"
            '60 SII 88" RHD
            • Pete
              • Jan 2007
              • 93
              Plow
              Chad. Hate to see the plow go into the scrap pile. I may be interested in it. Shoot me a message at pgrosso@maine.rr.com
              Pete
              • Tim Smith
                • 1504
                Hmmm chains
                Hey Chad,
                I could use some old farmers chains like those. If you are going to toss those too then any way you can toss them out the window on your way through lower CT on it's way home?
                Just tell me where abouts you tossed them out (highway and exit #) and I'll find them.
                Cheers,
                Tim "Dumpster Diving" Smith
                • Cristina
                  • Jan 2007
                  • 8
                  Plow
                  If it does not work out with the person before me I would be interested in the plow. Email me at ccalado1@yahoo.com or you can call me 908-578-5040.
                  Thanks
                  Cristina
                  • Tim Smith
                    • 1504
                    Thanks
                    Cristina
                    You mean the chains?
                    At first I was thinking that we might have an olde fashioned scavenger hunt on our hands but your area code is in NJ. Chad would have to have one heck of a bad throwing arm to miss by that much.
                    He he he...
                    • Tim Smith
                      • 1504
                      Doh! Just re-read your post Cristina... "I would be interested in the plow" was missed the first time round.
                      Still funny though.
                      • SweetPear
                        • Aug 2007
                        • 21
                        Attention "Dumpster Diver" and Cristina
                        I would have to have a pretty good arm to be able to throw those chains all the way from NY border into Redding CT
                        Cristina, I sent you an email.
                        • Tim Smith
                          • 1504
                          Originally posted by SweetPear
                          I would have to have a pretty good arm to be able to throw those chains all the way from NY border into Redding CT...
                          Okay, then just throw them *at* Connecticut. I'm in NY all the time and know that my spidey-senses work just as well over the border.
