guys it seems that my series 3 frame is not true , the right side of the truck sits lower by an inch, I have measured many areas and it seems to be the frame , is this a hard job for a body shop to pull it any thoughts would be great ,thanks
advise on frame work
Have you ruled out a sagging leaf spring, this happens to lots of folks?
How did you come to the conclusion it's the frame? Post pictures.1969 IIA - Tan
1969 IIA - Blue -
Yeah, one side of your springs sag some, flip flop them if you are worried about it (may not fix it).......1"???? I'd roll on.1969 IIA - Tan
1969 IIA - BlueComment
I had the same issue on my 109. Right rear was low.
Had the springs re-arched and put teflon sheets between each leaf.
Leveled the truck.Comment
This is related to that other post you just created regarding something odd about your spring mounts or something--I don't remember. If you post a picture or two of what you're talking about there, you'll get plenty of responses and the remedy to both these related issues will become obvious, I suspect...--Mark
