1970 IIA 2.25 88" May have found a good deal on a Warn 24V military winch. Can I add another battery and create a 24V "leg" to run the winch? I was also thinking I could also use the 2nd battery to jump start the first one should I need it. In my Google searching somepne said "get a series parallel switch and another battery" anyone know what that means? You guys are smart, is this possible? Thanks pb
24v Winch by adding another battery?
Running two 12V batteries in series creates 24V. Running them in parallel remains 12V. Using a switch to go back and forth is fine for the winch(only being used on 24V) but the truck can't handle the 24V side of it so you'd have to isolate the use of the winch from the rest of the vehicle or step the 24V down to 12V to the truck only. You can retrofit the winch with a 12V motor right from Warn (or your favorite electric motor supplier) which is easier and probably cheaper.Jason
"Clubs are for Chumps" Club president -
Just convert the rest of the truck to 24v.
That could be exciting also...in a constant scavenger hunt kinda way!Jason
You add a second battery with a jumper series cable to make the output 24V (connect the 12V battery to the negative terminal of the second battery). Run the winch from the 24V output. You run the truck from the first battery 12V. Charging, now that's a whole 'nuther issue.Comment
I recently put a 2nd battery in my boat and used http://www.bepmarine.com/home-mainme...lusters-manual
and will at some stage use the same for Andy the Landy, was ridiculously cheap less than 1/5th the cost that auto electricians were talking about, and all marine grade.
again, in my head, you should be able to get a 24v feed off the two batteries and leave the rest of the outputs at 12v, you would need diodes etc, but is doable. worst case would be inverter to get it up to AC voltage then step it back down to 24The problem with the world is that intelligent people are full of doubts, While the stupid ones are full of confidence.Comment
Like I said, cheaper, easier and more reliable to just source a 12V motor for the winch....Jason
amateur electrical tinkerer reply... that would work if you put Diodes on those cables to the 2nd battery, otherwise the whole system becomes 24v. 24v feed comes off the 2nd battery that is run in series, leaving the feed to the vehicle off only the first at 12v.... It works in my head anyway.
It's how gazillions of trolling motors are connected.Comment
Thanks for the link to these switches. I'm also going to research how trolling motors are wired. Still waiting on the Warn model number so I can price out a 12v motor conversion.
pbLast edited by NC_Mule; 01-06-2014, 10:27 AM.Comment
Wow, nice pic man!
So the positive red line out of "winch" is that 24v? If I run the rest of the truck off of "house" I assume that will still be 12V even though the negative side of "winch" is hooked up to the positive side of "house"
Thanks for the thoughts on this.
pbComment
The main drawback to this, in my opinion, is that the second battery is not isolated from your start battery.
As the winch draws down both batteries, the charging system is putting voltage into the start battery. The voltage to charge the winch battery is "leaked" to it. I doesn't get a direct charge. The negative consequence of this is that you can quickly flatten both batteries. If you are without means to get restarted, you could get stuck.
For extended winching with 24V, you should really add a second 24V alternator and battery system that is completely separate from your 12V electrics. 24V has many advantages.
Oh and you would want a big fat Schottky diode to isolate the second battery as it will reduce voltage drop if you were really worried about any current backflow. A properly sized one will run you about $50 at digi-key or mouser.Comment
