Change back to positive earth?
  • johnny2rovers
    • Dec 2013
    • 59
    Recently acquired my first Series vehicle. '65 IIA currently neg earth w/alternator. It has been suggested to return to pos earth w/generator. I am trying to get to original. Current wiring is junk, so whatever the change, money is not the issue, something has to be done.
    i would like your feedback, neg w/alternator or pos w/generator, a '65 and a good specimen.
    '65 Series IIA, 88'
    '00 Discovery II
    '08 Jaguar xj8
    '95 RRC LWB, deceased.....
    '75 Forward Control GS, 72 FL 64, gone to CA!
  • stomper
    • Apr 2007
    • 889
    What are you going to be using the vehicle for? Garage Queen, overland camping, joy rider? There is no real benefit to switching to positive earth except for originality if you are going for a concourse restoration that you won't be using. There is a reason people switch to negative earth, and an alternator.
    • I Leak Oil
      • 1796
      Trying to make the truck "original" would be the only reason I can see to switch back to that setup. You can live well with both setups but one just limits what you can do with the electrical system a little more. OK a lot more.....
      • luckyjoe
        • 335
        You don't need positive earth to run a generator.
        Tom P.
        1965 exMoD 109
        1995 RRC LWB w/EAS
        • I Leak Oil
          • 1796
          Out of curiosity who, in general, suggested changing it back and did they say why? A '65 is by no means a rare truck and having a - earth, alternator system isn't going to change it's value unless it's a true museum type restoration.
          As Tom pointed out you can still run a generator on - earth...but then it's still not original.
          • antichrist
            • Mar 2009
            • 272
            Yup, unless you're going for concours showing I can't think of a single reason to convert it back.
            Ok, one reason, you like to remove a battery cable while the engine is running. That would be a reson to have a generator.
            I'm also curious why the person said to covert it back to positive earth.
            Tom Rowe
            62 88 reg
            67 NADA x2
            95 D1 - R380
            95 D90 - R380
            97 D1 - ZF
              I'm going to guess that it was a fella with a last name of Lucas. Something about his ancestors being masters of reliable vehicular power distribution and this negative-ground thing was just a passing fad. Kept muttering "They'll be back grandpa. They'll be back."
              • johnny2rovers
                • Dec 2013
                • 59
                I keep neckties too. They come back! I'll not say who, but a well known restorer. I just thought I would float it. Not going to do it.
                '65 Series IIA, 88'
                '00 Discovery II
                '08 Jaguar xj8
                • flighht2k5
                  • 17
                  With an alternator you can take off a battery cable and the engine will still run.
                  Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety.
                  Benjamin Franklin
                  • I Leak Oil
                    • 1796
                    I think generators are just far more tolerant of it than an alt., especially for any extended period of time.
                    • JimCT
                      • 518
                      sorry no
                      over the road trucks that run up 100's of thousands of miles run alternators.
                      1963 Unimog Radio box
                      1995 LWB RR
                        He meant tolerant of suddenly removing all the electrical load by disconnecting the battery cable, a practice that can be harmful-to-deadly for alternators that don't have built-in load dump protection.
                        • antichrist
                          • Mar 2009
                          • 272
                          I didn't say it wouldn't run. At least until the alternator dies. So yes, you can remove it, but you have a high chance of frying the diodes. The alternator needs the battery to control the voltage. No battery and the voltage can spike to over 100v. That voltage is likely to fry the diodes, and other things on vehicles with computers.
                          Tom Rowe
                          62 88 reg
                          67 NADA x2
                          95 D1 - R380
                          95 D90 - R380
                          97 D1 - ZF
                          • I Leak Oil
                            • 1796
                            Without a battery connected???? What are you talking about?
