I have a 1972 SIII with a 2.25 petrol engine.
After seeing the blue smoke getting worse I did test the engine today. Smoke is less when the engine is warm but does blow out some when changing gears going up hill. Here are the compression test results for you all! #1 dry = 80psi and wet = 90. #2 dry= 75, wet = 90. #3 dry= 75, wet = 90. #4 dry= 90 and wet =90.
Thoughts? Valves? Head gasket? Something else? What do you recommend I do/ get done?
Thanks, S
Thanks, S
