Series II bulkhead repair
  • DGG
    • 304
    Just wanted to know if anyone has the measurement between the two bulkhead to chassis mount holes. I want to make a jig and I can't measure accurately with the transmission in the way. Thank you. My workshop manual does not have that measurement.
    Doug
    61 Series II 109 SW
    95 RR County LWB
    06 Range Rover
    98 Discovery LE
  • LaneRover
    • 1743
    You either need giant calipers or get to know some of that Pythagoras' guys work.
    I'd measure but am in the same boat as you . . .
    • o2batsea
      • 1199
      54.5 inches as I recall center to center
      I do know that the distance from center to the outside of the chassis is 15.5 inches, so you can measure from the side of the chassis to the hole and add that to the result. So, (15.5 + X)*2=Distance between holes.
      • DGG
        • 304
        Thanks for the help.
        Doug
        61 Series II 109 SW
        95 RR County LWB
        06 Range Rover
        98 Discovery LE
          Umm...You might want to verify that information...
          Looking at the large coachbuilder's drawing for the 1962 109 on TeriAnn's site (linked below) the center of each bulkhead outrigger hole to the vehicle centerline appears to be 29.562", making the bulkhead outrigger hole-to-hole distance 59.124" (59 1/8").
          As far as I know, bulkheads haven't changed any in that dimension over the years, but I don't know a whole lot about that, so take that for what it's worth.
          Note that I haven't verified this by measuring anything, but you could easily measure your own hole-to-hole distance by hanging a plumb bob off the center of one of the outrigger holes and marking the bob's location on the garage floor, then do the same for the other outrigger hole and measure the distance between marks. That way obstacles (like the transmission) are irrelevant.
          Link to TeriAnn's coachbuilder drawing:
          http://www.expeditionlandrover.info/...awingLARGE.jpg
          • DGG
            • 304
            As far as I know, bulkheads haven't changed any in that dimension over the years, but I don't know very far so take that for what it's worth.
            Note that I haven't verified this by measuring anything, but you could easily verify this by measuring the hole-to-hole distance by hanging a plumb bob off the center of one of the outrigger holes and marking the bob's location on the garage floor, then do the same for the other outrigger hole and measure the distance between marks. That way obstacles (like the transmission) are irrelevant.
            Very nice Mark. I remember seeing that drawing, but couldn't remember where. That's a big help. I will do the plumb bob thing too to have a couple of reference measurements.
            Doug
            61 Series II 109 SW
            95 RR County LWB
            06 Range Rover
            98 Discovery LE
            • o2batsea
              • 1199
              There ya go!
                I believe there are chassis dimensions in the factory manual and/or the Haynes manual. Probably a little easier to read there.
                  There is, but it doesn't show that dimension, just the chassis alignment checkpoints.
                  TeriAnn's drawing is easy to read once you click on it to super-size it.
                    Supersize it! Check!
