I have a 1971 2.25 Petrol engine that, when I bought it was told was converted to Unleaded and compression raised to 8:1. Originally, it ran poorly (it sat in a garage for 10 years and the old fuel had created varnish in all sorts of parts). After trying a few times to get the original Zenith carb to run well with rebuild kits, I bought the Weber 34ICH carb from our hosts here and installed. It now idles like a purring kitten at 700 rpm and once warmed up, comes up to speed relatively fine. However, top end power is pretty poor trying to get up even the smallest hills over 35 or 40 mph. I was assuming this was just the nature of the 2.25 petrol engine and was researching a 200TDI swap, but low and behold, one day recently, I forgot to push the choke in, and I "relatively" zoomed up the local hill I had struggled with. I experimented, and the car definitely runs better and much stronger high end with the choke 75% closed. I checked the Vaccuum advance lines for air leaks, carb base for leaks, etc, but do not see any.
I see anidle adjustment, but I do not see a high speed adjustment on the 34ICH. Does anyone have any suggestions to help? I read some threads related to tuning the engine that suggest the factory timing specs are not advanced enough for current ethanol-mix fuel, but that doesnt seem to answer the air limiting creating more power.
