Swapping engines 2.25 to 2.25 in a '65 IIa.
- Should there be any play at all in the main shaft coming from the gear box in the bell housing?
- Moly grease -- how much moly in the grease is acceptable? Napa has a version, but it does not say any specifics about it?
- Timing: If the new engine was running fine when it came out of the donor truck, is there any reason to go through a full timing set up, or should I plug in the distributor and adjust from there? ...if that makes any sense... for some reason, the concept of timing and why and how makes sense to me, but the actual mechanics of how to do it are not manifesting in my head the way most stuff does. I can usually picture things and get things figured out ahead of time, but it just isn't working for timing.... so sorry if I sound totaly ignorant, but I've been reading the green bible, hand books, haynes, pictures, online, etc... still can't get it.
