Hi,
I have a 1970 Series IIa 88" Landrover with a steering problem. At motorway/freeway speeds it tends to wander a bit, and keeping it in a straight line is a challenge (if not a little hair-raising).
I have adjusted the steering box as per the standard maintenance instructions (which are to jack up the front, loosen the adjuster bolt, then tighten by hand only before tightening the locking nut). This has not changed the handling at all.
So I'm looking for some suggestions as to where I go from here... do I get the alignment checked first? Could my relay be buggered? Should I add oil to my relay (or should I follow the maintenance manuals and stay the hell away from the relay and replace it altogether)? My ball joints are relatively new, so I don't think it's wear in there... Or should I just tighten the steering box adjuster bolt further with a spanner rather than just by hand?
I'm running mud tyres, which probably doesn't help the handling much.
Any suggestions appreciated...
Cheers,
Perk.
PS: This is my first post here, so bear with me if this has been covered already...
Cheers,
Perk.
