Floor plates and tunnel cover
  • IIA
    • Apr 2010
    • 161
    The floor plates and tunnel cover in my 1970 IIA are (barely) attached with a mix of different screws and bolts--where they're not missing entirely. I'm planning to replace all of them but I'd like to get close to what was originally there. It looks like the oldest fasteners on the floor plates are truss headed machine screws. Does that sound right to you? And how about the tunnel?
    Also, I read in the Haynes LR restoration manual that the floor plates were glued down. Has anyone else done that?
    1970 Series IIA
    1964 Series IIA [sold]
    Don't imagine yours is too different than on the SIII:
    • CMorris
      • 66
      Not glue, strip caulk, 3M part number 08578 in a box, or one of many others out there on rolls (rolls are easier to work with).
      Colby
      • IIA
        • Apr 2010
        • 161
        Great drawing. Where does that come from? I assume those are part numbers. Does it give any details (bolt and washer sizes, etc.)?
        1970 Series IIA
          Series III Parts Catalogue. In the back sections of the book is a section with the nomenclature for every part number. Some of the hardware have size details listed and some just say "washer" or "nut" etc.
          • greenmeanie
            • 1358
            Large diameter slotted truss head machine screws in 1/4-20 do the job. You'll need a set of matching J-nuts and some normal hex nuts and washers too. Available at Ace Hardware or if you fancy the Stainless look they can be had from McMaster Carr.
            Having just pulled the tunnel and floors from a TD5 Defender I view RTC3744 as the spawn of Satan and all have been replaced with standard cage nuts.
              Funny, those are the only ones I like. The rest are a pain in the butt.
              • TeriAnn
                • 1087
                You can just order a set of the correct parts from Rovers North. You get proper everything with proper finish. All brand spanky new.
                • Revtor
                  • Apr 2012
                  • 265
                  "Mortite"is a strip caulk available in HD/Lowes. Comes on a big roll that will last you a few years and its cheap. Doesn't harden and sticks well.
                  ---- 1969 Bugeye ----
                  ---- 1962 Dormobile ----
                    If you seal up the floor boards, how will the water drain out?
                    • greenmeanie
                      • 1358
                      Wow, who knew they originally came gold plated.
                      • Les Parker
                        • May 2006
                        • 2020
                        RN offers RNK822 for Series III and RNK823 for the Series II/IIa. Is it worth scratting about with odd nuts/bolts/washers or fit the Genuine parts and end up with the correct finish.
                        2p
                        Les Parker
                        • yorker
                          • 1635
                          Sure for 2 pence I could see buying the kit, but for now I'm afraid my frugality will mean I will soldier on with the assortment of fasteners I have.
                          Land Rover UK Forums
                          • jac04
                            • 1884
                            Originally posted by Les Parker
                            RN offers RNK822 for Series III ...
                            I bought this kit when I restored my Lightweight. It's a nice kit, but I thought it was expensive years ago when I only paid about $50 for it. Now it's $100.
                            • taffhill
                              • Feb 2013
                              • 17
                              Drill holes to drain it http://forums.roversnorth.com/images/smilies/sly.gif
