Hello, happy Friday. I wanted to share a few photos of my Series IIa project, mostly fishing for ideas of other items I should address while the truck is disassembled. I bought the truck in E.Oregon (high elevation desert) and it is amazingly rust free. It was sold with an engine that was 'pulled from a running truck'. Turns out that the engine had low compression on two cylinders, and since I dont have anything better to do during winter in Oregon, I decided to rebuild the engine to stock specification.
While the engine is at the machine shop, I decided to sandblast, prime, and paint the frame and firewall using good-old rustoleum. The frame has no rust, so I thought it would make sense to preserve it as best as I can. While it was apart, I replaced most of the seals and gaskets on the transmission, pinion seals, refurbish the gas tank, new u-joints for the driveline, new brake lines (that was not fun), and a few wiring harnesses.
Photos are here: http://flic.kr/s/aHsjRbKn4X
I wanted to ask a few questions while I have your ear:
I wanted to keep the stock 15" wheels, can anyone recommend a tire size that is commonly available to fit these wheels? Also, should I run tube tires or tubeless? The vehicle will see mostly city driving with occasional light off-road use.
For the tail lights, I never had the lenses, and so I dont know if the brake lamp (red) goes on the top or bottom (with the orange turn lens in the alternate position)? I could trace the wires, but I have seen both orientations in pictures of other SIIa trucks.
Should I worry about internal frame preservation, and if yes, is there an accepted method (Waxoyl?)
Thanks for all the information on this Forum, it is incredibly useful.
Cheers, Mike in Portland.
