Cold Amps
  • IIA
    • Apr 2010
    • 161
    Cold Amps
    During the recent polar freeze, I noticed that my heater fan won't start until the engine's been running for a while (much longer than needed to warm-up the engine) and the turn signal light (inside) flashes a lot slower than usual. Over-reving seems to help both. I'd assume it was my battery but I have no trouble starting. What could be causing this? I assume it's the cold by why?
    1970 Series IIA
    1964 Series IIA [sold]
    What was your battery voltage during all this? What was your alternator (or generator) output voltage during this situation?
    • IIA
      • Apr 2010
      • 161
      The dashboard ammeter was normal. I didn't check it with a multimeter. The headlights worked too, though they got brighter with reving.
      1970 Series IIA
        Alternator?
        • antichrist
          • Mar 2009
          • 272
          Well...one theory is that during really cold weather the electrons in the copper molecules of the wire are afraid move house and go next door. It takes them a while to get up the courage.
          An alternative theory, and the one I prefer, is that your alternator isn't putting out good voltage at low rpm. Or you have faulty connections in the wiring.
          It's possible the heater motor is a separate issue and the motor is gummed up and takes a while to free up.
          Tom Rowe
          62 88 reg
          67 NADA x2
          95 D1 - R380
          95 D90 - R380
          97 D1 - ZF
          • o2batsea
            • 1199
            how old is your battery? Alternator or generator?
