If it were me, I would use the mechanical lever on the fuel pump to fill the fuel bowl in the carb for a few mornings, to see if that is indeed your problem. That way you will know for certain that your pump hypothesis is correct.
fuel pump
There it is. So it's not the fuel pump. I suspect it's your "rebuilt" carb. The choke is working properly? All I can say is that I have always found that a new out of the box carb trumps a rebuilt one every time.Truck runs perfectly when warm, by the way; it's just cold start that's a PITA.Comment
You are aware if you leave the ignition switch on with the engine not running and the ignition points are closed you will be getting a continuous current flow through the coil and points. Over time this can damage your ignition system . Have you considered a switch just to run things you want to run with the ignition off and not have the ignition system powered up?
About fuel pumps. Carbs used on Series trucks like low pressure & high volume. You only want about 3 lbs pressure. Most electric pumps pump more like 7 -14 lbs pressure and can cause fuel to force its way past the carb's float valve. If you do not locate a low pressure pump you need a fuel regulator to lower the pressure of a higher pressure pump.
Electric pumps are good at pushing fuel but poor at sucking fuel so should be mounted no higher than the frame.
If you have a rear fuel tank you should mount the pump and filter on the outside of the frame. The inside gets engine, gearbox and exhaust heat and on hot days the temperatures can heat up the pump & filter enough to vapor lock. The best routing I have found is along the top of the frame rail beside the brake line to the fuel pump. The best place I have found to mount the fuel pump is on the outside of the frame just in front of the outrigger that mounts the front of the rear spring. The outrigger protects the pump from things slung by the rear tyre or parts of a disintegrating rear tyre.
Also with an electric pump you might consider adding an impact switch that shuts down your fuel pump in the event of an accident. I have one in my truck and so far it hasn't gone off while driving off road. But just in case I have it mounted within easy reach from the driver seat.
mechanical fuel pumps are often more dependable than electric fuel pumps. When mechanical pumps fail they usually keep working and pump enough fuel for you to limp along. When an electric pump stops working you are walking unless you carry a spare pump and tools.
Electric fuel pumps usually allow fuel to pass though when they are not on. Some people put them in series with a mechanical pump and leave them off unless needed as a backup.
Anyway that's just some miscellaneous thoughts about electric fuel pumps.-
As usual, I agree with Terriann. I am of the camp to use a electric low pressure pump in series with the mechanical pump with an on/off switch in cab to: 1. Prime the carb by filling the float bowl of the carb prior to starting. 2 .To use in case the mechanical one fails. I place the pump after the mechanical so it will not pump gas past a failed diaphragm of the mechanical pump, in the crankcase. Also o2batsea is right on about the carb needle valve and other other jets of a carb being obstructed/clogged in some way. Especially newly "Rebuilt" ones.
Cheers,
Rob
68 2a BugeyeComment
The Carter 4070 is rated at 6psi max - It comes highly recommended at various sites that specialize in Weber carbs - that's what swayed me towards the 4070.About fuel pumps. Carbs used on Series trucks like low pressure & high volume. You only want about 3 lbs pressure. Most electric pumps pump more like 7 -14 lbs pressure and can cause fuel to force its way past the carb's float valve. If you do not locate a low pressure pump you need a fuel regulator to lower the pressure of a higher pressure pump.
I understand Teriann's point about running at 3psi or so, but my truck has run great (winter and summer) for the past 3 -4 years I've been running this pump as is. I've considered adding a low pressure regulator but haven't gotten around to it because things have been working well.
If you are going to run an electric pump I would reiterate the importance of adding (for safety purposes) the oil pressure switch I described earlier. Only $18 or so.
TedComment
I would dispute Terriann's contention that mechanical pumps are more reliable, but she is correct that a mechanical pump can partially work, and in most cases an electrical cannot. That being said, that quality may be offset by things like a breakable bowl (ask me how I know), and diagnosis difficulties and the easy, cheap availability of the electric pump I have. After chasing fuel issues for about six months a couple of years ago, I am currently very happy with it.
In my case, after first, recurring annoyances with the mechanical pump (and it's replacement (and also two carb rebuilds, a couple of rewiring/regroundings, replumbing, etc., etc.) and then running through a few cheap (though not cheap) Mr. Gasket universal pumps, I did a bunch of reading on pump reliability rates and reputations and such. And anecdotally it appears that solenoid pumps are considered to have low failure rates and are widely used in OEM applications. By far the biggest complaint I found was the "ticking" kind of noise they make (and that's true, but no more annoying than most fuels pumps would be mounted that close to an uninsulated cabin (standard SII fuel tank setup). So I tried a pump like this.
http://i.ebayimg.com/00/s/NDkwWDEwMDA=/$%28KGrHqFHJCsE+,+L!vmuBQOi3Squ5g~~60_12.JPG
It seems the most well known brand of solenoid pump (OEM and aftermarket) is Airtex. Mine (from O'Reilly's, I think, but I can't remember and their site is being wonky) was not Airtex brand, but upon further examination the small print on the pump or paperwork said "manufactured by Airtex." it cost less $20, and I put it on a relay (which was actually part of a previous diagnosis attempt on another brand new, but bad-out-of-the-box inline vane-type pump, and in contrast to Terriann's contention, this was an example of an electronic pump that worked just enough to make me sure for awhile that something else was up (and so I tried EVERYTHING!) and I have it on a switch - primarily for the purposes of phone charging and such - and yes I know that puts my pertronix unit in a possible overheat situation, but anecdotal evidence is that it takes significantly longer than I would leave the key on, anyway (and has worked fine for about 2 years). Oh, and I have a Rochester. The pump is rated at 2.5-4 psi, so potentially a little high for the Rochester, but what I found doing research is that almost NO fuel pump actually pumps at it's highest rating. The tests I saw always had actual, real-world pumping pressure at or below the halfway point between the min. and max. The Airtex seems to work fine for me, though I did do some float adjusting after the pump got installed (and probably need to fine tune it at spring tuneup time).
Oh, also, I eventually just bypassed the mechanical pump and left it in. My original intention was to get a new mechanical pump installed, and leave it as a backup. But so far, a better plan seems to be to stock a backup solenoid pump (again, under $20) in my spares.Comment
