valve stems
  • Alk-3
    • Mar 2009
    • 185
    valve stems
    Hey Guys. I have 5 16" rims that I purchased here at rovers north. They are the after market rims. Not sure if they are proline or not. I thought they might have been wolf rims, that rings a bell for some reason. Anyway, I don't have the ruck nearby, it's up north a few hours away from me.
    Two of the valve stems have dry rotted and no longer hold air. I was going to grab some new ones on my way up to get the truck, but I dont which ones will fit. Do any of you guys know? not sure what the differences are between tr13 and tr14 or tr18.
  • jac04
    • 1884
    The difference between TR413, TR414, and TR418 is the length. They are all for a .453" diameter hole. The Land Rover steel wheels that I recently purchased have a larger hole, .625" diameter. So, you need to check the rim hole to be sure what you have. I use a TR415, which is a short stem (they stick out about 1.25"). This minimizes the chances of them getting damaged.
    • luckyjoe
      • 335
      I put TR413 valves in my Wolf wheels. They are 1.25" long, and as Jac04 says, fit a 0.625" rim hole.
      Tom P.
      1965 exMoD 109
      1995 RRC LWB w/EAS
      • jac04
        • 1884
        ^^TR413 are for a .453" hole.
        Did you mean TR415?
