69 SIIa ....
What is the correct routing for the clips and insulator bushings that hold the fuel line, vac lines, etc that attach to the 3 valve cover studs?
Position 1 (front) there is nothing attached but a clip resides there.
Position 2 (middle) I have the metal vac advance line in the clip.
Position 3 (rear) I have the plastic fuel line in the clip. I have since found that the fuel line should be routed to the front of the valve cover. But I have a Rochester carb installed.
Q#1 Does the high voltage coil wire mount in one of these positions?
Q#2 Does the 12v primary coil lead get mounted in one of these positions?
Q#3 Where is the factory fuel filter located (other than the f/p glass bowl)?
A pic with correct routing would be worth a 1000 words. :-)
Thanks,
Jeff
Thanks,
Jeff
