Brand new owner of 1969 Series with 2.25 petrol. Unknown miles on it. A loud engine knock brought the price into range so what do you do? Anyway I pulled the head and found severe damage to #2 piston head and less so to #1. Iron bits hammered into the aluminum. See pics. I pulled #2 and found the rings had come apart causing the piston damage. I figured to find the same on #1 but when I looked at it the rings were fine, gaps in range and no other issues I could see. I'm normally a bit slow but how did the bits from the rings on #2 do damage to #1? Would you all replace both just in case or is there some other explanation. Bottom end rod bearings all gaged out OK by the way.
The head has little to no damage from the rings. Smooth with a few scratches. Cylinder walls are also undamaged. Any ideas?
