What does the Lever Do?
  • RoveoJuliet
    • Mar 2014
    • 11
    I have a IIa 88 1964. Has a sideways movement lever in center low dash. Notches for positions. What is this? Is it normal equipment? What position should it be in when driving? Thank you. (novice)
  • darbsclt
    • Jul 2013
    • 166
    I'm assuming that you are talking about the manual throttle control.
    While one is fitted to my 88, I don't really use it. It's my understanding is that it is primarily used when operating PTO equipment - to maintain engine speed (if not, I'm sure to be corrected).
    • stomper
      • 889
      It is also used to increase the output of the alternator when heavily loading the battery for jump starts and winching, or to allow slightly higher revs when idling while the vehicle is cold, or as a really dangerous cruise control.
      • o2batsea
        • 1199
        Smoke release lever
          Originally posted by o2batsea
          Smoke release lever
          That could be any one of 'em PLUS all the switches.
          • RoveoJuliet
            • Mar 2014
            • 11
            Thank you very much. This forum is much cheaper than a manual. I am cheap, thrifty I like to say.
            • stomper
              • 889
              No substitute for the manual. It's referred to as the "Green Bible" for a reason.
              • Partsman
                • May 2011
                • 329
                Amen, so say we all!
                Series 2 Club Forum
                Andy The Landy Shop
                • TeriAnn
                  • 1087
                  Mine is white but that's beside the point. What he needs first is the owners manual. Telling you what the knobs do is just a small part of the manual. The manual also lists the factory recommended service items and intervals then provides step by step instructions on how to carry out each service item. The workshop manual does not go into tuneups & regular service items. The factory put all that stuff in the owners manual along with the wiring diagrams for that year LR.
                  • antichrist
                    • Mar 2009
                    • 272
                    Google 2a_owners_manual.pdf
                    Tom Rowe
                    62 88 reg
                    67 NADA x2
                    95 D1 - R380
                    95 D90 - R380
                    97 D1 - ZF
                    • RoveoJuliet
                      • Mar 2014
                      • 11
                      Thank you Tom. I Googled my Yahoo and whahoo! I got it!
                      • Apis Mellifera
                        • 386
                        I scanned and released into the wild a pdf workshop manual a few years ago. I can't remember if it is a Chilton or Haynes or something else. It has some before pictures of my SIII in the first few pages as filler. If you can find it online somewhere, it's better than nothing - pretty good actually, but no bible.
                        • Apis Mellifera
                          • 386
                          Here's a link from the days of yore about manuals. You can probably find the one I scanned as well as others by some clicking action:
                          • Partsman
                            • May 2011
                            • 329
                            I have a .pdf of the Parts Catalog here: http://www.mediafire.com/view/vooonj..._Parts_cat.pdf
                            It's a clean download.
                            Series 2 Club Forum
                            Andy The Landy Shop
                            • cedryck
                              • Sep 2010
                              • 836
                              That lever operates the james bond ejection seat.
